Bobcat A220 Aux Hydraulics Not Engaging
JWL
When we hit run on the right hand instrument panel all lights come on as the left instrument panel cycles through its start up. All functions on the left instrument panel work with the exception of the variable/maximum aux flow button. This button won't light up at all when pressed but the lights do work as I can see them during initial start up as noted above.
Is it the actual button itself (need to replace the face of the left instrument panel), is there a fuse dedicated to the aux hyds, is the left instrumental needing replaced, is there a ground or power source I check, etc.? Any help would be much appreicated.
Yesterday I unplugged the left instrument panel and plugged it back in and shortly after (not the first few attempts), the button did light up and the aux hyds worked. Apparently today they are no longer working and the light isn't coming on when pressed.
