Drive Motor Removal
pgr380
Trying to remove the right drive motor on my 751. I've removed all 4 bolts, the lower hydraulic hose and the smaller hose to the rear of the motor. Can't get my wrench on the top hydraulic hose, so I'm trying to pull the motor out for access. Problem is, the motor won't budge. I've attached a ratchet strap to it and pulled pretty hard with no luck. Any suggestions?
I'm not certain on this but don't you have to remove a bolt from the sprocket in the chain case if you're trying to take the motor and carrier out?
There is nothing holding that motor in other and an Oring, have you tried tapping the side of it with a soft hammer to see if you can crack the seal? There is no bolt holding it from the inside, the older machines had this.
