Hi people,new here to the forum.I recently purchased a 743 very cheap I have worked out the machine is between numbers 501911001 to 501914999. there was no drive when I purchased the machine so complete service on engine and new oil and filter in hydraulic system! still now drive,replaced bronze cented filter in the alloy block on top of the first pump and now the machine will move only just but will not turn!The boom will not lift also.It has a 4 in 1 bucket and holding the aux lever on until bucket jaw is open and continually holding the aux lever on and moving the boom lift pedal the boom will only just move approx 1/3 of the way,the other controls for the bucket work fine. REplaced all case drain houses,pressure hoses and charge hoses{they had damage and old age wear and tear}also replaced front pump to hydrostatic O ring and all other Orings on bungs and fittings that I could get at.Removed the spool valve and replaced all O rings in spool valve assembly. I have not checked for pressures yet. Pumps don"t seem to be too noisy. Hydraulic oil seems to be slightly aerated. My questions are,1what pressures to check and where,what are the pressures! 2what i can look at before i check pressures! 3any ideas about the boom operation! 4I can see that the small front pump has been serviced recently! 5I can see that the back large pumps have been apart some time ago! 6any help would be appreciated Thanks
