Does anyone have a Bobcat 753 That could take a picture of wiring for me
theboss
I am looking for pictures of the wiring that comes out of the right stick for the Aux controls. i have cut wires and cant figure out where they are supposed to go. I have too many un used connections.
Davross22
Hi .
How did you go buddy. I searched on the web via Bing. there is plenty there depending on engine fitted and what area you want.
T
theboss
i am trying to find out where the wiring goes out of the right joy stick. you have to lift the cab.
little_fellow
I have a 773C model that I could take pictures if you want. They probably have the same wiring schematics.
T
theboss
That would be cool. Do you have the right side joy stick that has a trigger and 1 switch you can move left and right?
little_fellow
I left the cab up so if you need more pictures, let me know.
  • IMG_0543.MOV
    5.1 MB
little_fellow
If you click on the picture, it will create a Download file at the top right hand corner of your screen and once the file is downloaded you can open it by pressing open file.
T
theboss
Thank you kindly for taking the time to help me out. Where do the wires on the machine side land? I only have 2x 2-wire solenoids that I can see and are right on top
little_fellow
those are the wires for your solenoids . I think that's What they are called. I took a couple of pictures . Just give me a minute so I can download them. Those wires hook up to a black and a green wire. One of the green wire has a red stripe on it and the other solenoid has a black and green also but I couldn't say what color the stripe.
little_fellow
I'm trying to send you the wiring section of my maintenance manual. Not sure if you have this. You'll see on the upper right corner of the wiring diagram where the 2 solenoids are the wires go from them and splice into the joysticks and onto the control module
  • electrical_system.pdf
little_fellow
Do you know where the Control module is? I circled a plate on your picture. The control module is on the opposite side of the machine. Identical plate. The control module is mounted underneath it.
stevelil
hello The Boss, I have a mid 1990's 753 with the "BOSS" electronic unit. I have a full shop manual and parts manual with full electrical schematics.
what is the serial number of your machine? The schematics are specific to serial number ranges and with or without BOSS systems. I'd be happy to send you the schematic and any photos from my machine that would help you. please let me know. Steve
T
theboss
508611787
From what I can tell I believe it is a 1990. I can't find any diverter valve which is what all the schematics I find have.
stevelil
give me a little while and ill dig them up. again does you syetme have a BOSS system or not?
  • Bobcat-753-Service-Manual.pdf
