diesel pump
woodeneye25
I have a 763 which is starving on fuel when you undo the line at the bulb fuel runs free /gravity . when its connected to the pump it stalls and wont hold rpm or go up hills i stuck a fuel tank on the roof and it runs a treat / so i thought i would use a 12 volt fuel pump to the bottom line to lift the fuel / i also replaced the fuel pick up into the tank and i didnt put on a the one way valve as i dont want to restrict the flow . well same shit !! still starving . can 12 volt pumps be used or not ? and who designed that fuel tank with the pick up under the main pump what a crap design. The roof tank is ok but the return lines keep over filling the main tank . / where to next im spent for a answer and sick of transferring fuel
Is the lift pump bad? the mechanical pump should make it work just fine.
lift pump check takes two, easy stalling have buddy grap squezzy ball if eng picks up r/r pump, or take time to put guage in line and montior while running. a pain but cofirmed;;
