I recently read an article (which I can dig up if someone is interested) about doing diagnosis with an oscilloscope and a clamp-on probe. So I bought a Velleman hand held scope and ordered a clamp-on probe. The goal is to accurately measure the lowest cranking voltage and highest amp draw and see if they are within limits. In this case one needs the scope as peak or min/max meters are not good enough. Lastly see that the charge current settles down after a few minutes to almost nothing. I don't have any problems in this area right now with skidder, but want to learn a bit on using a scope for diagnosis. Other things to try are looking at the cranking voltage/current draw (with fuel relay pulled) and seeing if one or more cylinders look different, thus poorer compression. Looking at the alternator waveform output to see if 1 of the 6 diodes are gone. So if anyone has any ideas or tid bits to pass along in this area it would be appreciated.
