ct 322
sinba222
I have a ct 322 skid steer and everytime time I turn the key the ignition fuse blows any help would be great thanks
Hi sinba222,
I moved your post to the JD section so it is more likely to be seen by some JD specialists.
Cheers - SR
There is a chance the switch is bad and shorting out internally?
A bad switched power cable could be it too. If it's rubbed through onto the frame, it will blow fuses like this.
