Is a s220 with a panel and the temp gauge is built in the panel unit .What model machine? if it's the round style gauge, it will be the sender or gauge
Sadly i can't help more than suggesting to replace the sender, the gauge is part of the manel and you can't just swap it out.Is a s220 with a panel and the temp gauge is built in the panel unit .
Yes it will do it sometimes then sometimes it never moves I’m thinking the panel is going out when I disconnected the sender it gave me a code and when I plug it back the code goes away on the right side keypadSadly i can't help more than suggesting to replace the sender, the gauge is part of the manel and you can't just swap it out.
When you start the machine, does it max out then return to the cold position? If so, it means the gauge its self is working, but either the sender or controller is the cause of the issue.
earlier in the year there was a guy who found a company that redoes the bobcat control boards and warrants their work. As I remember they were reasonable . maybe do a search and you can find that post, the symptoms that you describe sure makes me think bad ground, but bad board sure can be too. good luckYes it will do it sometimes then sometimes it never moves I’m thinking the panel is going out when I disconnected the sender it gave me a code and when I plug it back the code goes away on the right side keypad
Thank youearlier in the year there was a guy who found a company that redoes the bobcat control boards and warrants their work. As I remember they were reasonable . maybe do a search and you can find that post, the symptoms that you describe sure makes me think bad ground, but bad board sure can be too. good luck
https://isoscell.com/ Has anyone ever used this company they repair control panel’sThank you
