CODE: 32-65 ACS Sensor supply voltage out of range
thedassler
Hi All, Need a little help. In the vast experience of the forum, what is the most common reason for CODE: 32-65 ACS sensor supply voltage out of range? Thanks in advance!!
I guess it could be a few things, a bad sensor, bad connection or bad ground.
Sadly it doesn't say if it's high or low. If it's low, i'd suspect a bad connection reducing the voltage getting to the sender. If it was high, the alternator could be over charging.
One other thing to check is the fuse box. The fittings for the fuses can corrode, the fuse legs bay look good, the the socket they go into are not always as good.
