Charging
tyjay15
Hello everybody I am having an issue with my 2006 CT322 with it charging!
The alternator is charging at all times but when I release the brake switch the battery loses the charging voltage and the battery light comes on any advice would be much appreciated
Charging system not working properly. Check to see if the battery good (will hold proper charge at rest and under load), check to see if alternator functioning properly (voltage of battery should go up when engine is running, not go down). Check to see if you have good contacts with all the leads including ground. Look up YouTube videos to see how to check these parts for more detail.
