Case SR 240 no drive issue
Builder24
Hello,
Machine: Case SR 240 year 2018-2020 with hydraulic manual controls
Bucket tilts and lifts fine. Zero response when levers are pushed forward or reverse. Hydraulics are not engaging.
Lap bar and seat safety switch work.
Machine has 3k hours and lots of corrosion from working with agriculture amendments.
The instrument cluster was rebuilt as the machine was shutting off with light pressure applied.
All the relays and fuses have been checked and harness connections.
I suspect the instrument cluster was not repaired correctly or an issue with the ECM. Any suggestions would be much appreciated and thank you in advance.
