Case Drain Filter
farmboy55
What can someone tell me about case drain filters. Looking at my manual for my S185 it say's to change them when the hyd fluid is changed. I can't tell if they have been changed or not. My machine is so clean, 1200hrs. any thing I need to know before I change them. I'm sure they almost give them away. dennis
I have always felt that you really don't need to change the the filter , they are rock filters like old sytle Chevy carburator fuel filters, clean the filter wth cleaner and blow off with air , take care you reassemble it the same way it comes apart , that note of how the springs and rock face or it won't filter and let the trash go right thru , if you are concerned get some new orings , but they are reusable at 1200 hours
Thanks for the info. will I need to plug the lines off when I remove the filter?
All the ones I have done will at leak leak pretty good to flow quite a bit. Either have a cap that fits the threads where you remove the filter or have a helper hold a finger over the line while you change out/clean the guts of it. If there is room to set a coffee can in the right place (often times there isn't room) and you work FAST you can get done before the can fills up. Best to have a threaded cap or a helper who doesn't mind oil on their hands.
It just wouldn't be right if I didn't have it all over me and everything else!!!!! thanks for the reply dennis
