Case 435 Bucket Will not tilt.
Kgfarms
Have a 435, everything was running good and machine just died. Only thing I found was a blown 15 amp fuse, the spot the fuse is in is labeled with a lock symbol. I replaced the fuse and everything works now except for the tilt for the bucket, it's like something is keeping the joystick locked out that will not allow it to tilt. Checked all the linkage, fuses and relays everything looked ok. Any suggestions. Thanks
You have a fried lockout solenoid for the tilt circuit. Raise the arms, tilt the cab forward, and find the valve block for the arms and bucket on the right side of the machine. The lockout solenoids are on the front of the spools, on top. The bad one does NOT have the manual release pigtail on it, but it would be a good idea to do both.
