Greetings All I have a Case 1830 that I bought new during the Great Blizzard of '79. At 1100 hours and over 40 years it has been amazingly reliable. Last week I was giving it a little exercise when it felt like one of the chains on the left side briefly skipped a tooth or or was binding. Turns out the chains needed adjustment. But the problem is when checking the chains I found I could move the center cluster sprocket laterally about 3/8" or so. Checked the right side and that sprocket has no play. Pulled the shaft inspection cover and the bearing appears to be properly adjusted; no movement of the shaft. What would cause the sprocket to have lateral play? Since the Case is not often used and only for light work, can I get by with just a chain adjustment? Thanks for any advice.
