I am needing some help I have a case 1818 that won’t start unless you mess with the cable that you see in the picture once you move that it will start it will run for a while and then die out then if you mess with the cable it will start again I’m really not sure if that is for the choke or for throttle. The lever inside for the throttle is stuck is well any suggestions on a fix for it
