Brush Mower on TL8
mtnxtreme
Has anyone had experience running a low flow brush mower on a TL8 ? There’s so many options I don’t know what settings to use. One way flow, two way flow, and 4 different auxiliary hook ups ? Thanh’s in advance if anyone can help !
Has anyone had experience running a low flow brush mower on a TL8 ? There's so many options I don't know what settings to use. One way flow, two way flow, and 4 different auxiliary hook ups ? Thanh's in advance if anyone can help !
I just recently purchased a used TL8, a brush mower and a bucket grapple. Like you, I am struggling with getting the auxiliary hydraulics to work properly, but some of it could be the way I'm using it. Basically, it works sometimes, using the slider switch or buttons, and other times I get no hydraulic response at all. I have it set on one way flow, I believe. Curious to see how others set theirs up.
I have a 2015 TL8, did anyone get back to you, I'm also interested in how to set it up
ON my TL8R2 I enable the aux hydraulics with a rocker switch on the left panel, then the top left button on the left stick turns on constant flow to the brush mower. for my grapple, i just use the rocker switch on the stick to open and close the grapple.
