You guys have been a font of knowledge, I got the motor out of the T140, checked a bunch of stuff, repaired the oil pan, ended up doing a repair on the alternator bracket pivot(someone in the past messed it up, I fabricated a new bracket setup that transferred the load off the damaged mount onto the new steel bracket), motor is running like a champ, replaced a drive motor that was bad also. I took a couple pics, I'll post when I figure out how.....but I digress..... The T140 came back with the bucket hanging off, broken center piston, you know the drill. The main pivots on the bobtach came out, or, 1 did, snapped the taper pin. I've disassembled, and the tapers in the boom are good, but the pockets(?) on the bobtach itself are shot. I've ordered all the new parts needed(about 400 bucks) It appears the old ones need to be cut out, then the new ones inserted, lined up, and rewelded. I can do this, but has anyone done a write up, possibly with pics. Any tips? Any help is appreciated. Boss is on me on this, the machine is being retired and sold off. Getting a new T455 to play with.
