dfilbert1972
- Joined
- Oct 19, 2020
- Messages
- 1
Hello, I have searched this forum with no luck for my problem. I have a 2013 Bobcat T770 with the Kubota diesel engine. Last weekend it was running great and then just died like it was out of fuel. The fuel gauge doesn't work so I thought it could be out of fuel. it would only hold 4 gallons so that wasn't the issue. I replaced the fuel/water separator and flushed the lines. It wont start. I replaced the primer bulb and even added a 12V fuel pump thinking it wasn't getting enough fuel. I have cracked open each injector and I have fuel coming out when you turn it over but still wont start. I have replaced the inner and outer air filters. I did notice when you turn the key on you here what sounds like a pump that comes on for about 15 seconds then shuts off. when it shuts off the low fuel light comes on and i get an error of M0909 fuel level too low, but the tank is full and I have pumped about 5 gallons of diesel through the lines so I feel like they are primed again. any help would be appreciated.
