Bobcat T650 hydraulic issue.
GREENWOOD41
Hi all, I have a 2019 Bobcat T650 that has an Hydraulic operation issue. Would love if someone has experienced the same or knows the cause. The issue is lose of travel speed and power when operating the boom or bucket. The power and travel speed is fine on its own and so is the boom and bucket operation. but as soon as you are traveling or turning and use either boom or bucket or both at same time, I have a huge drop in travel speed and power. If I put the machine in a full left or right turn while holding the close bucket toggle it will actually stall the motor. All drive and boom and hydro function operations are fine and have plenty of power if used separately. Any ideas? Cheers
At first guess I would say you have a volume of flow problem , look at filters, kinked tubes, hoses , primary filter screens and it could be a worn pump too. thisw is a guess.
It may happen due to misalignment or some other reason. I think a hydraulic technician can help you.
