Thanks for the reply - we did what you said and the result was NONE. Any other suggestions or possibilities for our problem?Press and hold the lights button for 2 seconds. Did the hour meter panel show any codes?
Sounds like its not getting enough fuel(broken or clogged fuel pick up, clogged fuel filter, water in fuel)Thanks for the reply - we did what you said and the result was NONE. Any other suggestions or possibilities for our problem?
Could it be a bad hold coil in your shutdown solenoid?Sounds like its not getting enough fuel(broken or clogged fuel pick up, clogged fuel filter, water in fuel)
The fuel filter should have a drain on the bottom open it and see what comes out.
Thanks for all the assistance. Returned to the machine after 48 hours. It cranked, continued to run and we used it for a couple of hours without any problem. Must have been one of the shutdown systems that are advertised with this machine doing its job. All fluids are at proper level. Again, thanks for your assistance.I have seen the S175 have a pinched fuel line. I can not remember exactly where but will look tomorrow.
