Bobcat M500 Clutch Lubrication Pin Leak
M500
Hi, Newbie here with a question on a M500. I have a leak on the drivers right side front pin. It is leaking around the nut that tightens up on the outside of the engine compartment. It is not leaking from where the line is connected. I pulled it apart and blew air through and can hear it going into the reservoir and out the vent. Any suggestions are welcome. My local dealer wasn't any help. Thanks, Chris
I have read this post several times and I can not figure out what you are describing, can you try again to explane it again.
Probably the best thing to do is check the Bobcat Parts Online breakdowns for that section and see if there is a seal or O ring listed.
You could also peruse the facebook Melroe group, they tend to focus on these older clutch machines and have a lot of members / knowledge.
