Bobcat Gray DIY via Rustoleum oil based enamels
wateka
Location
Texas Hill Country
My head was spinning with all the helpful gray color suggestions and no store near me had any of the suggestions/base paints in stock, so I punted. I'm looking for protection, not beauty so I found Rustoleum Smoke Gray at TSC and said to heck with it. Well, at least until I put a sample on a cover plate. Protection? Yes. Anywhere close to Bobcat Gray? Nope. Luckily I had extra Rustoleum gloss black hanging around, so I just started adding black to the gray, while mixing, until it got close. It took about 1/2 quart of black to add to the 2 quarts of gray I had. Make enough to have leftover for touch up's.
I had to make more gray so this is more of a note to myself to have the formula somewhere accessible and in case someone want to replicate it. I also had to use a different Rustoleum Gloss Black so not sure if that made a difference but it took a whole lot more black this time.The last art class I took was in middle school and I'm going for protection, not perfection, so this is by no means 100% accurate, but it'll get you in the ballpark.
The Smoke Gray to Gloss Black ratio I used is 1 to 0.7061
If you're using a measuring cup, dump a quart (32 oz) of Smoke Gray in a mixing bucket and add 22.6 oz of Gloss Black.
If you're using a kitchen scale, see the picture below - there is approximately 849 grams of paint in a quart of Rustoleum oil based enamel.
