Bobcat 864 Solenoid Valve Coil Problem
SteveinNC
I called and talked to someone at Bobcat,they looked it up and told me that I needed the Solenoid Valve Coil with the following part number: 6671025 but when I received it,it didn’t fit because it has the wrong plug on it. My Skidsteer is a older model so maybe that’s the problem!?
If you go to Bobcat Parts Online you can enter your serial number and get machine specific parts listings. That's what the dealer should have done, see if you get a different part number than what they sent.
Thanks for the info,I’ll do that! Could it be something other than the solenoid valve coil? It starts up but it won’t lift or tilt.
If both the lift and tilt are inop, I'd strongly suspect some safety interlock that is preventing them from working. Having both circuits fail simultaneously is extremely unlikely.
If the lift tilt light is flashing I thought it was the solenoid and thought it was on the same circuit?
