Bobcat 853 Auxillary Hydraulics
Ausmarty
Hi All, I just purchased my first Bobcat, it's an 853 with high hours but it has been very well maintained, a problem I am having is the auxillary hydraulics lights start flashing and no Aux hydraulics, to correct the problem I turn the engine off and restart and they work again and the flashing lights go away, it will be ok for a while then it will repeat the cycle, Any Ideas ???
So the aux hydraulics work when you re-start?
Flashing lights sometimes shows when your alt is over charging or low battery voltage.
YES THEY ALL WORK OK WHEN YOU RESTART, I'LL CHECK THE RECHARGING SYSTEM TOMMORROW
Here is my experiencewith that one.
http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=7349
Thanks for that Ken, I'll have a look at the wiring, I used it today for about 2 hrs and it done it once, Tazza, the voltage meter is showing 13.5 v and seems to be constant, I did clean the earth cables where theyconnect to the body and engine Cheers, Marty
