Bobcat 825 Rad hoses and manuel
gofski
Hi Everyone ,New guy here, I am in Ontario .Just aquired a mid 1980,s 825 bobcat. Looking for lower radiator hoses ,2 right angle cranked ones that go from the low engine to low rad on left hand side also a manuel for the 825.Also anyone know if I can use any coolant in the rad! Any info as to where I can get these would be appreciated. Thanks Ed
Talk to the dealer for hoses, even loader parts source has some listed, not sure if it's for your model though.
As for coolant, you can run anything as long as you flush the system out first. You can't mix types, if you have green, you can generally add green, if it's purple you really need to add purple. Personally, dump what it has, flush it and add whatever you use in your car and stick with it.
