Your most likely correct, i called a heavy equipment mechanic and he said basically same thing, either the coil is weak or the stem, it didnt seem like it had alot of pull on the stem when energized, i could feel it pulling but could still move it, problem is i deal with alot 24v stuff that pulls harder when energizedIt's possible that the stem is bad? if the coil doesn't pull the stem to unlock it, you will not have that function. Unplugging the coil sounds like the coil shoudl be good, the blinking is an error saying the coil is open.
Figured it out, theres two metal solenoids on the front of the valve, one on top side is tilt, one on bottom close to lever is the lift, thats the one that was bad.Your most likely correct, i called a heavy equipment mechanic and he said basically same thing, either the coil is weak or the stem, it didnt seem like it had alot of pull on the stem when energized, i could feel it pulling but could still move it, problem is i deal with alot 24v stuff that pulls harder when energized
Glad you found it, the coils don't pull super hard, but you can feel them doing something, i assume they don't need heaps to move the little spool inside the stem to do the work.Figured it out, theres two metal solenoids on the front of the valve, one on top side is tilt, one on bottom close to lever is the lift, thats the one that was bad.
