Bobcat 773 losing power
bvinson9
Good morning,
I recently bought a 1998 773 with a kubota engine in it. I have been having issues with lose of power after about 30 minutes of use. Its will start to bog to the point of shutting off if I have the drive sticks pressed and when I release them it will go back to normal throttle speed. From everything i have read it points to a fuel starvation issue. Here is what i have replaced so far and the issue is still there.
New pick up tube and check valve. ( old one was broke off)
New fuel lift pump
New primer bulb
New fuel line
I removed the new pick up tube yesterday and saw some trash on the screen. Does the fuel tank need to be drained and flushed? Anything else im missing? Any ideas would be greatly appreciated.
Thanks
Good morning,
New fuel lift pump
New primer bulb
New fuel line
Thanks
Make sure you governor is operating properly.
