Bobcat 753 front lights not working
I have a bobcat 753 and the front lights are not working. I have checked the fuses, relays, and wiring. I also put another dash on it to check and that did not work??????
Did you check the bulbs and the connections at the bulbs? I had problems with the bulb connections on my older machines.
I switched to LED lights on my newer machine. Much brighter and they use less power.
are you getting power to the bulbs?
, maybe a mouse chewed a wire or just corrosion or broken wire ?
Is the switch panel at the top front of the cage? I had one that was having starting problems, but the lights were working. The 2 fuse holders in the key panel up there were corroded. I changed both of them while in there. The friend who owned it had rebuilt the starter, and then bought a new one that never started the first time. I troubleshot it and found the fuse holders bad. about $20 a piece original style at NAPA
