Bobcat 753 error code 32-49
sweden
I have the error code 32-49 ACS Lift acuator short to ground. I have replaced with Teo new acuators from Bobcat. The same error code. I checked the hardness between ACS controller to acuators and to the fotpedals and the joystick. Checked with ohm meter and everything looks good. At one place the protection of the wires was bad but the wires looks good. Can footpedal sensor be bad and give me that error code? I have switched the acuator cables and the same error code. Can I have the same error code if my firmware is old on the machine? Can I switch the right foot sensor with de left? Just to check if that is the problem?
