Check the primer bulb too!Did you check/change your fuel filter?
Yes, The first time it did it, it was very cold out we thought it geled up. So we put a fuel addative in and change the fuel filter. Bled the injectors.Did you check/change your fuel filter?
Yes, It was very cold the first time it happened, At that time we thought it geled up so we added a fuel additve and change the fuel filterDid you check/change your fuel filter?
The hand primer stays hardYes, It was very cold the first time it happened, At that time we thought it geled up so we added a fuel additve and change the fuel filter
Dude does it move fuel Though!!!!!? or not Cmon that is your job man!The hand primer stays hard
Yes Half fullDude does it move fuel Though!!!!!? or not Cmon that is your job man!
wow that is weird ,I am starting to wonder if your fuel tank cap vent is plugged or something weird like that.The next time it does that, quickly take your fuel cap off while listening for a vacuum in the tank. let us know what you find please.Yes Half full
have you checked the screen at the bottom of the fuel pickup tube?wow that is weird ,I am starting to wonder if your fuel tank cap vent is plugged or something weird like that.The next time it does that, quickly take your fuel cap off while listening for a vacuum in the tank. let us know what you find please.
No, how do you get them out, the line goes thru a rubber fitting into a plastic tank.have you checked the screen at the bottom of the fuel pickup tube?
You need to pull that plug out, its in a horrible spot to get to as well! Its attached to the bottom half of the elbow, there is a screen and 1 way valve built in. They can get covered in crud causing a restriction.No, how do you get them out, the line goes thru a rubber fitting into a plastic tank.
