Bobcat 743B
Rcasen
Any idea when I try to tun right just lightly it jerks bad, if I do a full speed, its fine, with good power on both sides, I'm hoping it's a common bobcat problem, I asked dealer, told me to do linkage adjustment, that made no difference. Thanks
I'd check the linkages from the steering levers to the pump, any wear in the bushings can cause jerking movement. If the arms on the pump are loose, it can do it too, less common on a 743 though, as they are steel.
