MikeLawrence
- Joined
- Aug 23, 2023
- Messages
- 20
Put new style quick connectors on 743B and added a case drain.
Will this work?
Will this work?
As long as the tank still has a way to vent it should work.Put new style quick connectors on 743B and added a case drain.
Will this work?
View attachment 10269View attachment 10270
Thanks for the reply.As long as the tank still has a way to vent it should work.
Not sure how the hydraulic line is run up the arm and over to the tank. Make sure that the hose does not bind or pinch and that the movement of the arms up and down does not put any pressure or twisting on the hydraulic tank where the new hose is connected. Maybe a clamp on the cab to make sure of no movement. The tank and caps are plastic and a tank failure could destroy your pump and drive motors.
You might think about adding a filter to that line. I know that room may be an issue, and the main tank is filtered, but another filter would add some peace of mind in case something internally blows on the attachment. You could add the filter to the attachment instead of the machine.
I tried it and it appears to work without putting tension on the filler cap. So far the flow keeps up with the screen filter.As long as the tank still has a way to vent it should work.
