Bobcat 743 more pull on right side
uffda
My Bobcat 743 seems to be pulling more on the right side. Is there an adjustment to remedy this?
Pretty sure you can adjust the steering linkages to give a little more or less movement for the sticks, you may be able to get it close to being right. It could also be motor wear, making it not move quite as fast as the other. If it's only a little over a good flat run, don't worry, but if it's a lot, an adjustment may be in order.
When I push the right side lever forward I go in reverse, goes forward when I pull it backwards. The left side works fine. Prior to had the drive motors inspected and told me they were fine. Was the right side motor put back together incorrectly. When I lift the bucket it seems to be dry from hyd fluid.
For it to operate backwards, i feel thaty have not timed it correctly when putting it back together.
