bobcat 743 few aftermarket part numbers
mattyc5094
******BOBCAT 743 KUBOTA V1702*******
FILTERS
OIL FRAM - PH16,PH43 HASTINGS - LF196
AIR INSIDE FRAM - CA255754 HASTINGS-AF631
AIR OUTSIDE FRAM-CAK253 HASTINGS - AF129K
HYDRAULIC FRAM -P6884, HASTINGS -HF719, BALDWIN – BT8861
DRIVE CHAINS #80H DIAMOND 14,500 (2-10' lengths will do all chains).
REDUCTION BOX BEARINGS SKF - BR3720, (2) LM501310, (2) LM501349, JLM506810, JLM506849
SEAL SKF- CR25713
AXLE BEARINGS TIMKEN – LM104949, LM104912 (2 of each per axle),
SEAL NATIONAL - 40301S
WHEEL STUDS 9/16-18 DORMAN – 610-380
WHEEL NUT 1" SOCKET DORMAN – 611-053
HOSES TILT CYLINDER (2) ½" 3500PSI 18" JIC-10 M/F
I'm wondering if 80H is a suitable replacement for the stock chain. An application engineer at Diamond told me the HS series would be a better choice for this application. Does anyone know the specs on the OEM chain?
