Bobcat 732
Hello, New to this forum and Bobcat. I have a 732 year unknown. I just bought an older machine a few weeks back that I am learning about. I am doing maintenance on it slowly to make it start better, hard to start first thing in the morning but will run the rest of the day. I changed the spark plugs and will change the fuel filter after I run the gas out and clean the fuel tank. the float and plastic is floating around in the tank. Right now though I would like to buy a grapple for it and the 732 is set up for attachments with the hydraulic lines up front. From what I have read the right forward and reverse handle controls the attachments when you move the handles sideways in each direction. My question is that they do not really move much as it sits without an attachment hooked up to it, will this handle move with the attachment hydraulic lines hooked up and fluid flowing to an attachment? Thanks in any enact for any help
They have a bolt that locks the function installed from the factory. Possible it has never been removed, or someone installed it to keep the auxillary hydros from engaging. You will need to access the lever pivot point and you will find a bolt that locks the lever. remove it. May want to save it, in case you want to reinstall it when your not using attachments.
Thank you I will look for that bolt today.
