Bobcat 732 Drain Hyd Oil Problem
You can do one of two things: one is to get a set of crowsfoot wrenches, they should be able to get the hoses off and on, or the other thing you could do is to dismount the filter head from the frame and move it down to where you can access the hoses with regular wrenches. If I recall correctly the filter head is mounted with slots somyou can back the mounting bolts off and then slide the whole works up off the bolts...
