I am not having much luck finding just the block. When searching for it I can find the block, jackshaft assembly used for $215 but without better pictures it's hard to say the condition of that. I haven't priced the jackshaft but the new block from Bobcat is $131.Wow….where to start…. personally, I would replace the jackshaft, block/splicer and both of the jackshaft bearings
The jackshaft is still available…Bobcat pt# 6551114….I don't know the price and rarely see them on E-bay. The block is available … Bobcat pt# 6502810….don't know the price but they are available on E-bay quite often….I have some if you need. They are pair/balanced with a mark on each half that needs to be matched up when installed. Bearings are Bobcat pt# 6518862 at $94.00 but you can get them on E-bay any day for $25.00 - $40.00….keywords (RA104RRB) I like the Fafnir the best but Timken work just fine. I hope you can reuse the pulley but if not it is still available….Bobcat pt# 6551201…about $30.00. The bushings in your 'driven' sheave look fine.
Roto-swivel assembly….there are too many parts to list so go to the Bobcat web site (bobcat.com) …. parts and work your way to the exploded view of the assembly. At a minimum I would replace parts #2, 4, 5, 7, 8, 25, 23, 22, 20, 19 and 18. That looks bad but only 20 and 23 are expensive….the rest are only a couple of bucks each. Find a manual and follow it closely for both of these jobs.
Hope this helps.
Most of the other parts I can find fairly easily so I am not worried about that. May just put it all in new from Bobcat rather than mixing and matching or buying used parts and hoping they're okay. But what would you charge for a set of blocks..?
Do you think the jackshaft is bent, is that why you suggest a new one?
It's a little bigger mess than I was hoping for but would like to get it running to use to help clear a farm site and move snow this winter so trying to get it all in check without spending an arm and a leg!
