bobcatrick
- Joined
- Mar 10, 2014
- Messages
- 2
Hi guys, I sure hope you can help me. I have a 1972 bobcat 600. The other day I was piling logs and tried to lift a particularly large log and the hydraulics were by passing because of to much load. suddenly a heard a small pop and the tilt stopped working. The lift and the variable speed all work normal but when I try to tilt I get very little movement and the weight of the forks cause the tilt to just fall down. What I am wondering is if it is likely the relief valve broke a spring and is stuck open? if so, is this found in the tilt control valve? Also I should mention that there is no external oil leak with this problem. Any help would be greatly appreciated. Thanks Rick
