Hello all, I have a 1990 543 that has an issue that I've been working on for a couple of days. After a half hour of running, I lose power and can't get any fuel to run through the primer bulb. Seems worse when the fuel level is low (below a half tank). I figured I either have a clog or an air leak that's keeping the pump from pulling fuel. This will probably be fairly straightforward to resolve, but I'm not sure if the fittings on the tank are removable, or if they are how to do it. Pull, twist, pry or what? Also, does this unit have the brass filter on the inlet side of the hydraulics like some of the bigger ones have? Thanks in advance for any advice. John
