Bobcat 463 bics help
Kcorey
Hello. I recently purchased a bobcat 463 with 3cyl kubota diesel and what I Beleive to be is a 2001. When I bought it I could not move the machine or use the lift . I bypassed the solenoids and was able to move it and use lift arms. The bics is showing no lights on at all, I checked the fuse for it and it is good . I unplugged the bics and tested for power at the plug and am showing no power to the plug at any of the pins. I do not have a wiring diagram for machine yet. Are the bics know to go bad? It only has 800 hours on it.
Thank you I will dig into it tonight!
Well I found why I had no power to the bics box, bad connection at the harness plug by engine . Fixed that and now have the power light on, seatbar light comes on when seatbar is down, and the traction lock and the lift arm lights just flash. I played with the button on top left by key and it doesn't change anything .
All fuses are good , I swapped relays for the brake and still the same thing
The number of times the lights flash before repeating is a code that's saying what's wrong.
Traction lock solenoid works fine if I manually power it . It is also new replaced by previous owner. The hydraulic control solenoid for lift arms also works fine when manually powered. And I looked for a chart in the codes for bics system but had no luck.
How many times does it flash before repeating?
I Beleive the traction lift flashes 2 times before repeating and the lift arm light flashes one time. I will double check tonight though .
Two times on traction..........traction lock hold coil circuit shorted to battery.....lift arm one time ......valve output is open
I get a double flash of both lights ( they both blink once at the same time ) then I get a 2 flashes of the traction light. When I hit the push to operate button the system activated light comes on .
So I re wired the connections where I was having issues. And I still get a single flash of both the traction and hydraulic arm lights when I start machine and put seat bar down. When I hit the push to operate button the system activated light comes on but still no movement of machine or arms. Single Flash of both lights then a double flash of the traction lock. Any pointers?
