I have a bobcat 310 that is having a low speed clutch issue. Hi speed works just fine. I have traced all the wires to ensure they are properly grounded. On start up clutch is engaged but weak, hydraullics work just fine. When I go to move it forward or back its moves slowly for a moment then stops and makes a weird noise. If i attempt to turn side to side it makes the same noise (reference video). Either scenario it stops moving all together. If i push the hi speed button skidloader works just fine in hi. Looking for any suggestions as I can't figure it out. Clutch resistance test results were within tolerance. Thanks in advance.
