Bobcat 2001 863 limited power
urcysk
It starts good and runs good for about 10 mins, than i have to hit the priming bubble repeatedly to get any power, it seams to run rough and when i manually pump fuel it runs fine? any ideas!! I changed the fuel filter
You have identified that it is fuel related, it could be a plugged pickup screen in the fuel tank or possible be a weak lift pump.
DEUTZ. LIFT PUMP CONTAINS A REMOVEABLE CLEANABLE SCREEN. FUEL RUNS TO IT, HAS AN ALLEN HEAD SCREW . COVER IS ROUND. IF CLEANING IT DOES NOT FIX ISSUE. REPLACE PUMP. SIMPLE TEST,,, WHEN SHE IS DOGGING OUT DOES A SQUEESE ON BALL PICK HER BACK UP. IF SO REPLACE PUMP. IF SCREN IS FILTHY SOURCEOF JUNK, NEEDS FIXED OR RIGHT BACK AGAIN,
