Thank you for this. Has anyone located a manual that covers earlier SN 743s with the Gresen valve unit? The load check locations are different. Thank youThis is a 35 meg fille, I was able to compress it. I have a scanned in copy of the bobcat manual also but it is 65 meg and would need to put it up on a FTP site and may at some time. This manual that I put up should be able to be used on any spool the theory is the same just more or less spools valves. I was given this file as well years ago.
Assuming no one ever used the aux hyd, have you had any issues starting to use it after all that time?I thought I didn't have aux hyd on my 743 but turns out I did . A bolt was locking it from moving L & R. if my knee accidently pushed it. Lift seat ( cab) to see if at bottom of R. hydro lever has a bolt in aux valve.
Did yours have connections on the front of your machine for aux hyd? Mine just has a bracket where the connections fit into but they're not there neither are the hyd lines that are needed for aux hydI thought I didn't have aux hyd on my 743 but turns out I did . A bolt was locking it from moving L & R. if my knee accidently pushed it. Lift seat ( cab) to see if at bottom of R. hydro lever has a bolt in aux valve.
I believe all 743's originally came with auxiliary hydraulics.Did yours have connections on the front of your machine for aux hyd? Mine just has a bracket where the connections fit into but they're not there neither are the hyd lines that are needed for aux hyd
Yes mine does have the connections.Did yours have connections on the front of your machine for aux hyd? Mine just has a bracket where the connections fit into but they're not there neither are the hyd lines that are needed for aux hyd
I think that maybe over the years if someone did not need the auxiliary and it started leaking or the tubes got hung up and bent, they would just plug them off and remove them.
Go to the parts catalog:
Bobcat Parts Catalog - Find Diagrams for Your Equipment - Bobcat Company
Locate all parts and component information about your Bobcat equipment with detailed visual diagrams and illustrations with parts numbers and add to your list.www.bobcatpartsonline.com
Enter your serial number and search "auxiliary". You should find the parts and get a general idea of where everything should be.
Here is a link to the parts catalog:see I have a bracket for the aux hydro connections to be mounted. Just don't know if this machine is equipped with them. If anyone can help that would be great
Locate all parts and component information about your Bobcat equipment with detailed visual diagrams and illustrations with parts numbers and add to your list.partscatalog.bobcat.com
You should be able to find the auxiliary components and where the spool is on the control valve.
I do see that at some point they were listed as an option so your machine may not be set up for them
