thanks. i should have mentioned that it has the kubota motor. i can't see a cord anywhere. i figured it didn't have one on it. but i know some of the auto manufacturers are very good at coiling that cord up and hiding it. so i thought i would check. thanks agian.If it's a Deutz engine, it's on the oil pan behind the starter, if it has one. Sometimes the cord is wrapped up and hidden in there, never used. If it's a Kubota-not sure-I think it's on the head, a freeze plug style. If you can't readily see the cord, it dosen't have one.
I have a a300 with kubota engine and the engine heater is in the block , very easy to see right in front of you when you open the back door. If it's not easy to see, it probably doesn't have one.thanks. i should have mentioned that it has the kubota motor. i can't see a cord anywhere. i figured it didn't have one on it. but i know some of the auto manufacturers are very good at coiling that cord up and hiding it. so i thought i would check. thanks agian.
