Blinking light codes
perry
My 853 has two green lights on the upper right instrument panel, these lights indicate status of aux hyd. The lights are blinking on and off opposite of one another, one of the BC mechanics told me the lights are indicating a 'problem code'. I didn't know this??, can anyone tell me where I can get list of the codes and what they mean.
Thanks in advance,
Perry
Ken has had this problem http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=7253 Good luck.......Jeff
Jeff, I copied and pasted in the search box but nothing?.
Perry
Send me your email address to [email protected] and I'll send you a copy of a fax I recieved from a 873 manual that has good information on this.
Mine turned out to be a almost severed wire from the steering lever harness, the 2 lights worked normal for 30 mins but then kicked into the alternate flashing mode (which disenguaged the hyd flow) as a result of resistance as the wire heated up.
It can be a bad contol box, new one for mine was $500.00 usd, it has the aluminum one behind the operators left shoulder under the cab. Look inside the ROPs hole where you check your hyd oil level, but on the other side, it has 3 wire harnesses coming from it, measures about 4 by 3 by 6".
The other option is a $175.00 box bolted to the inside of the frame by the hydrailic filters) and there is a 3rd option I was told) But it can be a broken wire or a poor conection in the harness, so hope for this.
It is not related to the BICS in any way
Perry
copy and paste to the address bar ....Jeff
Ken, my filter allows me to preview mail and then add as a contact, go ahead and send, I'll get it. And thanks....
Perry
You should have recieved it twice by now then..
I'll try again you can always delete the extras
