743 hydraulic light
Sparky87
Hey all, my 743 hasn't had the hydraulic light working since I acquired it. I have the service manual and my understanding is that it should light up momentarily upon startup. I know the hydraulic fluid pressure switch is the ground for the light and the hour meter - which is also not working. I replaced the pressure switch, verified it's working correctly and I made sure the bulb in the hydraulic light is good. Still nothing. Where else should I be looking? Thanks!
use a decent volt/ohme meter verify voltage supply and pressure switch is closed when idle and open when running
