backhoe model identification
tubby's repair
I have a backhoe attachment that i have to find parts for and the only type of number on the attachment is a number 230 stamped on a metal tag. The frame was orig painted construction yellow but someone painter it black, so it would match bobcat. I need the spool seals. It has 6 spools with 4 levers. The end plates on spools has 1 line on each side for aux hookups. Any help please. Thank you Wes
The seals should be off the shelf. If you can get them out, take them to a hydraulic seal shop. They should be able to match them up pretty easily.
