Auxiliary Pressure Release -S205 skid steer
Dan2791
I pushed the auxiliary pressure release button on the dash and it killed the engine, now the engine won't restart even after pushing stop button. Now throwing a 14-03 code which is for "fuel shutoff sol pull error off". Could these two be related?
Pressing the auxiliary pressure release button is supposed to kill the engine. You are actually supposed to hold it for 2 seconds after the engine stops to release the pressure.
I believe that the problem is related in that when you pressed the button it activated the fuel shutoff as was was supposed to. You probably would have had the same issue if you just pressed the STOP button. Probably just a coincidence that the problem occurred when it did.
