ATS Fail code new holland skidloader
Nappy701
I have a 2014 new holland L221 keep getting the ATS fail code it’s -5 here so I assume fuel is gelling up I added anti gel to tank and the other bottle that suppose to degell if it’s already froze up.. removed fuel filter and filled half full with deice. Will idle for 20 seconds and die. Anyone have any tips
The only thing you can try is installing new fuel filters, however I doubt that is the problem. The only way to find out what the problem is, is to have your dealer connect their laptop to your machine so the fault codes can be recovered. Only then will you have some idea of where to start. There may also be a code shown in the display before ATS shows up. If there is a code present this code probably does not have any relation to the ATS fault. Welcome to tier 4 engines.
