My machine will not move. Loader works perfectly, but tracks will not move. I believe there must be a valve closed not allowing fluid to pass through, or some kind of solenoid or something. Any ideas would be appreciated.
Odd..... Almost sounds as if it could be something broken between pumps. I assume lift/tilt work, but no drive. Generally the pumps are inline, the first sections are drive then the hydraulic pump. So when it goes, you loose lift/tilt, not drive..... Hopefully someone that knows ASV machines will pop their nose in, never worked on one before, sorry.
